Hi:
The widget‘ number may be just lacked for me. Can I create a widget and import to studio?
@金龙 高: The functionality to add custom widget is not available in current release ( version 8.0.3) and is already planned so should be available in future releases.
-Durgesh
-Durgesh
Thanks!
Do U have any documents about "home.js".I had some problem with writing code.
@ 金龙 高: It will be helpful if you can provide details on some of your issues encountered which will help to get better understanding of the problem.
I would suggest to check out sample codes available on our Help section which you can use/modify as per your need.
-Durgesh
