Thingworx studio widgets?
金高
Hi:
    The widget‘ number may be just lacked for me. Can I create a widget and import to studio?
dupatel
(To:金高)
@: The functionality to add custom widget is not available in current release ( version 8.0.3) and is already planned so should be available in future releases.
-Durgesh
dupatel
(To:金高)
-Durgesh
金高
(To:dupatel)
Thanks!
Do U have any documents about "home.js".I had some problem with writing code.
dupatel
(To:金高)
@ 金龙 高: It will be helpful if you can provide details on some of your issues encountered which will help to get better understanding of the problem.
I would suggest to check out sample codes available on our Help section which you can use/modify as per your need.
https://help.thingworx.io/studio/#page/ThingWorx_Studio_Help_Center%2FIntermediateTutorialsIntro.html%23
-Durgesh
