Toggling mute and unmute for audio in vuforia studio / but also settig of the volumen control
RolandRaytchev
because so far I see,  the post  (question by @Ace_Rothstein ) is already closed and there is no possible to add a solution or  workaround  to this post, therefore I want to open extra topic for some further considerations of the issue and will  try to provide a solution /workaround  for this item.
Following steps:
1.)To be able to  get access to an audio or video widget first we need to receive the audio object. To get the  angular element object of the audio widget following js code could be used:
var nameAudio="audio-1'
var myaudio = angular.element(document.querySelector('twx-widget[widget-id=\"'+nameAudio+'\"] audio'));
2.)The next step is to  set the value of the control mute property  to the  toggle value /  negated value  = ! toggle.value
 e.g.:
let toggle =! $scope.view.wdg[nameToggle].value
myaudio[0].volume = toggle;
$scope.$applyAsync()
3.)you can define a function implementing the point 1 and 2 and set this function  to the toggle Wdiget UI JS Box change event:
The function definition could be something like this:
$scope.toggleAudio  =  function(nameAudio,nameToggle) {
4.) Now when we test it - we will the desired behavior :
I attached a project example which demonstrates the issue /implements a demo solution
Great! That is an amazing solution. Precisely what I was looking for.
1 REPLY 1
