Trial extension
MSD2
Trial extension
I need help in extending the trial for some more time.
Dhinesh
11 REPLIES 11
dupatel
(To:MSD2)
@MSD2  Please confirm if you have already clicked the option to extent Trail post login to Studio Trial portal
Also, please share your user ID if you would like us to check the extension status internally.
-Durgesh
MSD2
(To:dupatel)
Hi Durgesh,
I am not able to find the trial extension option in the link provided.
dupatel
(To:MSD2)
@MSD2  Could you please share screenshot post login to https://trial.studio.vuforia.com
MSD2
(To:dupatel)
PFA
dupatel
(To:MSD2)
@MSD2  As per the screenshot, I do not see your trail got expired. Your trial account is still active and once expired you will get an extension link on the portal.
-Durgesh
MSD2
(To:dupatel)
Thanks Durgesh,
I face another issue in publishing experience. Attached the error which is popping up when I try to publish an experience.
dupatel
(To:MSD2)
@MSD2  Could you please share complete Studio application logs to review the publishing issue.
-Durgesh
MSD2
(To:dupatel)
Hi Durgesh,
Please find the attached logs file
dupatel
(To:MSD2)
@MSD2  It seems there is some issue with your Proxy setting as there is an error related to it. Please review error and make sure ES URL is not getting blocked by your network or firewall.
GET /api/switch 200 1.121 ms - -
[2019-05-23T12:50:17.137Z] error: [twx-studio:proxy] Proxy error { Error: connect ETIMEDOUT 10.76.52.78:80
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1113:14)
errno: 'ETIMEDOUT',
code: 'ETIMEDOUT',
syscall: 'connect',
address: '10.76.52.78',
port: 80 } null 200
MSD2
(To:dupatel)
Hi Durgesh,
There is no firewall restrictions. It was working fine earlier.
dupatel
(To:MSD2)
@MSD2  Strange, as the proxy error indicates there is some change with network setting or details. Are there any other changes done in the evironment or application setting? Also, share studio application setting proxy server details snapshot ( click on 3 right dots ... while launching studio URL)
Could you please check to connect to an external network like home wifi or mobile other than your Organization network.  Does this work?
-Durgesh
