Hi Guys,
I'm new to Vuforia Studio so i try to figure out, how some mechanics work.
What I want to do is, I Want a 3D-Picture turn on, at for example by Step 5 and turn off by Step 8.
I already can select a sequence from a 2D-Select Widget, press play and see the animations.
$scope.setsequenceList = function(){
$scope.app.params.sequenceList = [
"display":"Item1",
"value":"app/resources/Uploaded/l-Creo%203D%20-%20Sequence%202.pvi"
$scope.setsequenceList();
Now only my 3D-Picture "Warning" is missing. I already found some guides but i'm not able to transfer the solutions into my problem (Beginner Level with Coding).
https://community.ptc.com/t5/Studio/Play-specific-step-of-PVI-sequence-at-studio/m-p/552906#M3362
and
If you can help, I would appreciate 🙂
Hi @Yasar ,
One of the ways to implement this scenario is as follows:
$scope.$on('$ionicView.afterEnter', function(event) {
let view = event.targetScope.view;
console.log('viewContentLoaded', view);
$scope.$watch('view.wdg["model-1"].currentStep', function (stepVal, oldVal) {
console.log('model step changed', stepVal);
$timeout(function () {
$scope.changeImage(stepVal);
}, 10);
$scope.changeImage = function (step) {
if (step == 5)
$scope.view.wdg['3DImage-1'].visible = true;
if (step == 😎
$scope.view.wdg['3DImage-1'].visible = false;
Hope this helps!
Hi @Yasar ,
}, 10);
if (step == 5)
if (step == 😎
Hope this helps!
