Can anyone at PTC confirm if the Experience Service is down at the moment? I cannot view or publish. If the Service is down, when is it likely to return to operation?
Brian
@bwhelan The ES services has been restored and should be available. Please check and confirm.
-Durgesh
@bwhelan Experience Service is instance specific and request to please share the URL so that we can check & take action internally on its status ( online/offline).
-Durgesh
@bwhelan Yes, please direct message the URL and it will go as a private message to the sender only.
Durgesh
-Durgesh
Hi Durgesh,
All good. I PMed you regrading this too.
Many thanks for the assistance,
Brian
