The launcher will not allow me to open Vuforia Studio. The open button is greyed out. There is an error message in the log file, "Node Sass could not find a binding for your current environment".
I have tried uninstalling Vuforia Studio from control panel, deleting the folders
"AppData\Local\Apps\2.0" and "Documents\VuforiaStudio", then re-installing Vuforia Studio using the trial setup.exe.
After re-installing, the error remains. I have attached the log file below.
[2022-03-17T03:19:23.077Z] Studio 9.3.2.5397
[2022-03-17T03:19:23.091Z] Status Message: Getting ready...
[2022-03-17T03:19:23.091Z] Starting node.exe
C:\Users\65972\Documents\VuforiaStudio/ssl-settings.json
[2022-03-17T03:19:24.470Z] info: [twx-studio:index] Studio Version 9.3.2.5397
[2022-03-17T03:19:24.503Z] info: [twx-studio:initializer] Node version: 14.17.6
[2022-03-17T03:19:24.504Z] info: [twx-studio:initializer] studio launched with the following arguments: {
_: [ 'C:\\Users\\65972\\Documents' ],
'$0': '..\\..\\..\\..\\..\\..\\Roaming\\VuforiaStudio\\studio-download.vuforia.io\\dist\\server\\index.js'
[2022-03-17T03:19:24.509Z] info: [twx-studio:initializer] studio dir: C:\Users\65972\Documents\VuforiaStudio , home dir: C:\Users\65972\Documents
[2022-03-17T03:19:24.520Z] info: [twx-studio:builderSettingService] C:\Users\65972\Documents\VuforiaStudio\builder-settings.json was not found, creating it now
[2022-03-17T03:19:26.765Z] error: [twx-studio:index] unhandledRejection Missing binding C:\Users\65972\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\node-sass\vendor\win32-x64-83\binding.node
Node Sass could not find a binding for your current environment: Windows 64-bit with Node.js 14.x
Found bindings for the following environments:
- Windows 64-bit with Node.js 14.x
This usually happens because your environment has changed since running `npm install`.
Run `npm rebuild node-sass` to download the binding for your current environment. Error: Missing binding C:\Users\65972\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\node-sass\vendor\win32-x64-83\binding.node
at module.exports (C:\Users\65972\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\node-sass\lib\binding.js:15:13)
at Object.<anonymous> (C:\Users\65972\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\node-sass\lib\index.js:13:35)
at Module._compile (internal/modules/cjs/loader.js:1072:14)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1101:10)
at Module.load (internal/modules/cjs/loader.js:937:32)
at Function.Module._load (internal/modules/cjs/loader.js:778:12)
at Module.require (internal/modules/cjs/loader.js:961:19)
at require (internal/modules/cjs/helpers.js:92:18)
at Object.<anonymous> (C:\Users\65972\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\dist\server\utils\projectHelper.js:18:22)
Read this article - "Unable to open Studio after upgrading from Studio 9.2.3 to 9.3.0": https://www.ptc.com/en/support/article/cs361105
