As stated above I'm facing this issue since morning, whenever I'm trying to publish it is asking me to login as I'm logging in with correct credentials still it is asking me to login again and again. Even happening the same when trying to validate. Please help me out I have demo tomorrow.
@nv-2 Are you using Vuforia Studio Trial instance or commercial instance? Please share the Experience Service URL and Studio application logs to review.
-Durgesh
Hi @dupatel I'm using commercial instance. this is my URL: https://3lnktwct.studio-trial.thingworx.io
and I have attached the studio logs file.
@nv-2 The URL shared is not commercial and is Studio Trial instance. Could you please confirm your trial is still active and not expired. You can confirm that post login to https://trial.studio.vuforia.com/ and share us the screenshot of the same.
Also, please share the username used for log in to Studio Trial so that we can check internally if there could be any other issue.
-Durgesh
Vuforia Studio trials have been down on and off the past few days, it should be resolved now if that's the only issue! (Source: I've been having the same issues)
