I'm having trouble with publishing projects since updating to 8.5.12.4700.
Vuforia displays this error when publishing.
Log file output as follows:
[2020-09-02T00:19:45.239Z] error: [twx-studio:projectHelper] publishTask error for project Target_Test_02_09_2020 Failed to output zip.
[2020-09-02T00:19:45.240Z] error: [twx-studio:api] Error occured while publishing project Target_Test_02_09_2020 Failed to output zip.
[2020-09-02T00:19:45.254Z] info: [twx-studio:ves-publish:1599005985216:Target Test 02/09/2020] filter out entry: extensions/js/libthingview_wasm.wasm
Hello Micah,
It seems a Target Model or Image is used in this Project due to the name Target_test.
If the answer is yes, I would recommand to look these articles :
https://www.ptc.com/en/support/article/CS311736
https://www.ptc.com/en/support/article/CS300040
https://www.ptc.com/en/support/article/CS321715
Best regards,
Samuel
Where do I find the log of the Vuforia Experience service?
I've published experiences previously with variations on the name target_test. Also, this experience published fine when I've exported it and and imported it onto other machines.
Hello Micah,
Thanks you for your feedback.
It is more clear from my point of view.
It is a local issue on the workstation, not in the server.
I would like to see the verbose before the one reported before to find a possible root cause.
By the way, I have found this article :
https://www.ptc.com/en/support/article/CS320078
It is similar but in our use case, Project name seems to be valid.
Best regards,
Samuel
