Hi everyone!
How can I delete/update experiences downloaded in Vuforia View for offline viewing? I know that there is instruction which says:
Problem solved, I was using wrong gesture to do it. You have to hold your index finger on downloaded Experience, not try to "click" it 😉
We recently had the same problem and in our case we were in the wrong menu:
Did you go to the offline Experiences list before using the gestures? (Voice command "Hey View" - "Show Downloads").
There, the gesture should provide visual feedback on the experience name, after which the corresponding menu for updating and deleting opens.
Greets Pierre Bättgen
Hi there!
Sorry for a late replay. Yes I am sure I was in downloads menu. According to PTC Support I should do these steps to delete/update experience:
