Using Variables in Vuforia Studio
DG_10787729
Hello everyone!
I'm trying to change the text of a widget if it meets the criteria in the if-statement. This should happen everytime a property on Thingworx is updated.
This is how my js-code looks like:
SubscribeTest -> thing
A1F -> thing-property
Force_Indicator -> gauge
maxForce -> application parameter
My question is, if it is possible to use variables like this and if yes, then how?
And is there a detailed documentation about variables in Vuforia Studio (e.g. what you can do with them / how to use them)?
Software:
ThingWorx 9.6.1-b253
Vuforia Studio 9.25.6 (9.25.6.0)
I would really appreciate some help.
You might be able to accomplish this with a simple binding and a filter. Try binding your A1F property from your thing directly to your gauge, and then add a filter to that binding that reads something like this:
if (value >= 200) {
  return twx.app.params["text"];
else {
  return value;
if (value >= 200) {
else {
  return value;
DG_10787729
(To:ClayHelberg)
Hi @ClayHelberg!
Thank you for your help!
I only had to return the text for it to be displayed.
For some reason I didn't even consider applying a filter to the param.
I really appreciate your help!
Best regards,
Dan
I'm glad it worked for you!
