Validate an assembly again a 3d solid in a specit step
Hello all, hope you are safe.
Maybe someone has an idea how to resolve this. I dont know how to validate a step created en Vuforia agains the real model using the model target. The idea is verify if the user has had assembly correctly the real product comparing it agains how the 3d model in that specific step should look like, if not, the user will recibe a warning, if the assembly is correctly them the user could continue with next steps.
Thanks in advance for your time
Luis
