Hello, I'm trying to use Video widget with mp4 file from experience server.
when I do:
$scope.setsrc=() => {
$scope.view.wdg['video-1'].videosrc='/Thingworx/FileRepositories/UL.FileRepository/Vid_20190531_125615_1.mp4';
And then hit play it works fine in preview and Android, but on iOS I just can't make it work. (when I click play widget resets)
Does anyone have an idea how to solve this?
Kind regards
Hi @mziemniewicz and @ClayHelberg,
I think there is another solution I just tested which could be more independent from the visibility of the Thingworx server. So, for this way you need solely the access of the Experience server
Follwoing steps:
1.) checking the path of the path on the repository:
2.) set the permission of the service LoadBinary of the repositorything to run for 'es-public-access'
3.) add the service in the External Data in Vuforia Studio project :
4.) add e.g. a button click event to the video widget play service:
5.) add the following javaScript code;
////////////////////Issue with read video from repository $scope.GetVideoFromTwxRepository = function(path) { $scope.$applyAsync(function() { $rootScope.$broadcast('app.mdl.CAD-Files-Repository.svc.LoadBinary', {"path":path} );} ,500 ); console.log("after calling GetImageFromTwx"); }; //////////////////////////////////////////////////////////////// $scope.$on('$ionicView.afterEnter', function() { // register the LoadBinary-complete event + callback $scope.$root.$on('LoadBinary-complete', function(event, args) { console.log("LoadImage-complete event"); console.log("name="+event.name) console.warn(args.data); console.warn(args.data[0]); var ret_str='data:video/mp4;base64,'+args.data[0].Content; $scope.view.wdg['video-1']['videosrc']=ret_str; console.warn($scope.view.wdg['video-1']['videosrc']) }); //call the function to laod the mp4 file to video source of the video widget $timeout( function () {$scope.GetVideoFromTwxRepository( '/web/c-belt-converyor.mp4' );},500); }); ////////////
6.) Test it in preview and on mobile device- I tested in Android and IOS Ipad 6 - and it was working fine
Hi @mziemniewicz,
what is the path what you use here for the setting of the videosrc property ? : '/Thingworx/FileRepositories/UL.FileRepository/Vid_20190531_125615_1.mp4'
Is this a local folder in your project or did you try to use /as the name says/ a FileRepositriy from Thingworx?
the full path is like:
Is it possible on your IOS device to play it from there/the mention repository link/ in other app or browser?
I found that in order to access content in a File Repository thing, I had to add the es-public-access appKey to the URL, along these lines:
$scope.GRAPHIC_REPOSITORY_URL = "https://vmqlbmkm.studio-trial.thingworx.io:8443/Thingworx/FileRepositories/MyGraphicStore/"; $scope.makeGraphicHref = function(id) { var appkey = "?x-thingworx-session=true&appKey=4xxxxxxxxxxxxxxxxxxxxxxxxxx"; return $scope.GRAPHIC_REPOSITORY_URL + id + appkey; }
Follwoing steps:
Thank you so much! This solution is the only one that works perfect! 🙂
