Video widget in iOS
  • September 2, 2019
  • 4014 views
Hello, I'm trying to use Video widget with mp4 file from experience server.
when I do:
$scope.setsrc=() => {
$scope.view.wdg['video-1'].videosrc='/Thingworx/FileRepositories/UL.FileRepository/Vid_20190531_125615_1.mp4';
And then hit play it works fine in preview and Android, but on iOS I just can't make it work. (when I click play widget resets)
Does anyone have an idea how to solve this?
Kind regards
Best answer by RolandRaytchev
Hi @mziemniewicz  and @ClayHelberg,
I think there is another solution I just tested which could be more independent  from the visibility of the Thingworx server. So, for this way you need solely the access of the Experience server
Follwoing steps:
1.) checking the path of the path on the repository:
2.) set the permission of the service LoadBinary of the repositorything  to run for 'es-public-access'
3.) add the service in the External Data in Vuforia Studio project :
4.) add e.g. a button click event to the video widget play service:
5.) add the following javaScript code;
////////////////////Issue with read video from repository
$scope.GetVideoFromTwxRepository = function(path) {
 $scope.$applyAsync(function() {
 $rootScope.$broadcast('app.mdl.CAD-Files-Repository.svc.LoadBinary',
 {"path":path}
 );} ,500 );
 console.log("after calling GetImageFromTwx");
 $scope.$on('$ionicView.afterEnter', function() {
 // register the LoadBinary-complete event + callback
 $scope.$root.$on('LoadBinary-complete', function(event, args) {
 console.log("LoadImage-complete event");
 console.log("name="+event.name)
 console.warn(args.data);
 console.warn(args.data[0]);
 var ret_str='data:video/mp4;base64,'+args.data[0].Content;
 $scope.view.wdg['video-1']['videosrc']=ret_str;
console.warn($scope.view.wdg['video-1']['videosrc'])
 //call the function to laod the mp4 file to video source of the video widget
$timeout( function () {$scope.GetVideoFromTwxRepository(
'/web/c-belt-converyor.mp4'
);},500);
6.) Test it in preview and on mobile device- I tested in Android and IOS Ipad 6 - and it was working fine
Hi @mziemniewicz,
what is the path what you use  here for the setting of the videosrc property ? : '/Thingworx/FileRepositories/UL.FileRepository/Vid_20190531_125615_1.mp4'
Is this a local folder in your project or did you try to use /as the name says/ a FileRepositriy from Thingworx?
the full path is like:
where http://mycloudexperienceservice.com:8080/ this is the same address for Thingworx and the experience service of this particular experience.
Follwoing steps:
 {"path":path}
 );} ,500 );
);},500);
