Vuforia Chalk
SOLVED
Highlighted
Marble
Vuforia Chalk
Hi All,
 I searching how to lauch "Vuforia Chalk" trough a Vuforia Studio Experience with a widget "button".
Is it feasible? Someone already tried ?
Any advice on JS code ?
Thanks for your help
Lionel
1 ACCEPTED SOLUTION
Highlighted
Re: Vuforia Chalk
Hi, so in the short term, I suggest you use a Hyperlink widget (and style it as a button if you wish), and then put vuforiachalk:// as the URL. Please note that this is not officially supported, is not a universal link (i.e. doesn't work unless the Chalk app is already installed), and isn't something we've tested thoroughly. Therefore, use at your own risk (should be sufficient for a demo). The Studio team has a Chalk widget in the works which should address your use case, but doesn't have a fixed release date yet. Thanks
14 REPLIES 14
Highlighted
Re: Vuforia Chalk
This feature is currently not available but is on our road map for future releases.
Highlighted
Re: Vuforia Chalk
OK, thanks for your answer.
Highlighted
Re: Vuforia Chalk
Hi @Lionel_Brly -- just noticed this question (and @tmccombie provided an accurate response).
We currently have app deep-linking, but it's not officially documented and supported.
Could you provide more context on what you're hoping to achieve or see? Are you a Vuforia Studio user and trying to configure a Studio widget?
Dan
Product
Dan Hitomi
Product
Re: Vuforia Chalk
Yes, I can give you some details.
I'm a PTC Partner in France, My role is Pre-sale Director.
This request is not really coming from a customer in terms of "usecase", two weeks ago, I did a demonstration on Vuforia Studio and on Chalk, this demo has been well appreciated by the customer, and I had a lot of questions during this demo, particulary on "how to contact an expert ?"
During viewing an experience (Maintenance usescase) if I misunderstand something, something is missing to understand the details, how can I contact an expert ? (To have a audio & video conversation)
it seemed obvious for me to use "Chalk" and by consequence, to be able to launch "chalk" from an experience.
What can be the differnts steps?
1-Launching a Vuforia experience
2-In case of needs, have an access  to "Chalk" through Button
3-Access to "Chalk"'s address book
4-Select an Expert
5-Open a connection
To be honest with you, the integration of the two products, seems to me to be an interesting business opportunity.
For your information, this integration has been presented (PPT Slides) during a PTC Webcast on Augmented reality, in French for French PTC Partners ans Customer, last week.
Do not hesitate if you need more detail.
Please keep me in the loop if any decision about integration.
Thanks.
Lionel
Highlighted
Re: Vuforia Chalk
Snapshot from the PTC Webcast.
This can help you to understand.
Lionel
Highlighted
Re: Vuforia Chalk
Hi @Lionel_Brly - thanks for the sharing the screenshot.
FYI - I didn't realize at the time of responding the last time that I was in the Studio community. I had received a direct link to this thread and assumed I was posting under the Chalk community. I'm the Product Lead for Chalk, so I'm familiar with the slide you're sharing as our team prepared it.
Let me check in with a Studio PM to see if they can help here. The slide you shared is the intended, near-term experience we'd like for our Studio customers to be able to initiate a Chalk call. We've been demo'ing the app-to-app flow (achieved via app deep-linking in Chalk) for a few months now.
Dan Hitomi
Product
Highlighted
Re: Vuforia Chalk
Highlighted
Re: Vuforia Chalk
Ok it's very clear, I just tried with just an URL, it's working, as you wrote, for the momentit'll be ok for demo.
Thanks a lot for your help.
Lionel
Highlighted
Re: Vuforia Chalk
Hi All,
I need to know  how I can use Vuforia chalk on top of vuforia studio.
I went through some links provided in ptc community also but people have given solution to add a button or navigation button which will navigate to Vuforia chalk from studio. But I want to implement on top of studio.
Is it possible?
Any document or help wrt this implementation will help.
Topics available:
AR/VR for Data Optimization AR/VR for Security and Control AR/VR for Inspection
