Vuforia - Kepserverex connection
anaclos
Hello, I need to read tag values in Vuforia from KEPServerEX. Can it only be done from Thingworx or is there another option?
pandersson
(To:anaclos)
You can do http requests from studio. You need to enable rest in kW, you may need iot-gateway license to do so.
An issue I can see is the security issue, kepware runs with a connection to ot-network and letting phones/ipads connect to that is normally a no-no.
pandersson
(To:anaclos)
You can use the rest-server to get data from kepserver.
But you need to refresh the request manually to get the updates.
Per
anaclos
(To:pandersson)
Thanks for your answer. Can it be done in Vuforia Studio? Or is another installation required?
pandersson
(To:anaclos)
