Hello, I need to read tag values in Vuforia from KEPServerEX. Can it only be done from Thingworx or is there another option?
You can use the rest-server to get data from kepserver.
But you need to refresh the request manually to get the updates.
Per
Thanks for your answer. Can it be done in Vuforia Studio? Or is another installation required?
