Hey everyone! Could Vuforia Object Scanner be used for Vuforia Studio Experiences for Model Targeting?
If yes, could you please provide an example how it could be implemented?
Best Regards
Olena
Can you please elaborate it what you want to achieve in model targeting for Vuforia Studio?
Short answer, no.
Long answer below:
Vuforia Object scanner is used by Vuforia Engine for small objects like toys and it generates an .odt output( if I remember correctly) which is not compatible with the model target tracker.
If you want to scan a model for model target, please review this article: https://library.vuforia.com/articles/Solution/how-to-create-model-targets-from-3d-scans.html
Hope it helps.
Marius
