I'm having issues with the software installation progressing to about 60% and then failing due to one of the files' computed hash being different than specified in the manifest. Has anyone else experienced this or aware of a workaround?
Could you please confirm from where have you download the software and which version you are installing. Also, please provide the screenshot of the error and you might be facing issue due to bad/incomplete download of software for which you can retry a fresh s/w download.
-Durgesh
Adding to Durgesh Patel reply - also try to make sure your network isn't restricted. May be try installing from a NON-Private network.
-Giri
