Vuforia Studio Binding Filter Functions
MS_9637805
2-Guest
Hi, I was planning to manipulate the data coming from Thingworx Service using the following:
return value.trim().replace("\"}]","").split("\":\"")[1]; with an example input being:  [{"result":"Data"}] . I want to implement this code in the binding filter but the output will contain nothing. Please help.
what kind of manipulation you want to see it ..............can you please elaborate it.
I tried to convert float value to integer coming from thingworx platform and i used following code. please check if it may help u
return $filter('number')(value,2);
To simulate Thingworx input, I create a Application Parameter:
TWX-input: [{"result":"Data"}]
Then bind to widget "valueDisplay-1"
Edit Filter: return JSON.parse(value)[0].result
In Preview
Is this meets you need?
