For some reason I am not able to validate the experience service and publish my experience in Vuforia Studio.
Any ideas?
See below.
I would appreciate some help.
Bill
Hello Bill,
R&D has extended this trial instance.
Also, you have been registered as a partner now with this instance.
In a such case, the trial will not expire again automatically.
So, no need of an environment in PTC Cloud as explained in my previous post.
Best regards,
Samuel
Hello Bill,
First thing to check, does the Experience Service is running or reachable ?
For that, in your web browser, run this URL :
https://<Your Experience Service URL>/ExperienceService/ping
Second thing to check for a trial instance, does this instance is not shutdown or decommisioned.
Can you give your email address used to have this trial, please ?
Best regards,
Samuel
Hi Samuel,
Thanks for your help.
I ran the URL. See Result below. It says "OK."
My email address is: bdrosos@boundarysys.com
So, the Experience Service is running.
A second quick test can be done.
In Chrome web browser when using this URL https://0675cbeab33b2654.studio-trial.vuforia.io/ExperienceService/ui
I have done it and the result reported is :
{"message":"Inactive tenant","errorCode":"","error":{"status":404}}
In my trial Experience Service, I have a credential popup.
So, I suppose that this instance has an issue.
I am looking that with R&D and I will come back to you.
Best regards,
Samuel
Samuel,
Thank you.
I think that my Vuforia trial may have expired and caused this issue.
The company I work for, Boundary Systems, is a PTC reseller.
Would I be able to get the licensed version?
Bill
Hello Bill,
Yes, the feedback of R&D confirms that too.
They are looking to restart it and extend the trial time.
I have checked the PTC Software Download web page for Boundary Systems.
Vuforia Products are not listed.
To have the license, the solution is to contact the PTC License Management.
The best for that is to open a case.
Best regards,
Samuel
Hello Bill,
Best regards,
Samuel
