Hi Everyone,
The 3DImage widget's click event doesn't work when viewed through HoloLens, can anyone please help me out with this.
Thanks in Advance,
Aditya Gupta
Hi, you can not click an 3D Image by just tapping with your finger on it like it is working for the 3D Buttons. This would only work with an air tap gesture.
Is it possible to use the 3D Image Button instead of 3D Images?
Can you please elaborate it more about what you want achieve with event
Hi @Suraj_Patil ,
I want to do something whenever an image is click in Vuforia Studio for Hololens.
you can check with links below. it may solve your problem.
Hi @sebben ,
It's possible to use button but since the image wasn't clickable in Hololens hence I wanted to clarify it.
Also, to click an image in Hololens experience is air tap the only option?
Thanks.
Yes, air tap is the only option to click an image in Hololens.
