Vuforia Studio is not starting. LocalHost not found
Petter
3-Newcomer
Hi, I have issues with Vuforia Studio.
Its looking for a localhost: http://localhost:3000/ in my broswer but there is nothing loading.
From Log:
[09/25/2018 11:47:23] Studio 8.3.3.3744
[09/25/2018 11:47:23] Status Message: Getting ready...
[09/25/2018 11:47:23] Starting node.exe
[09/25/2018 11:47:30] info: [twx-studio:initializer] Node version: 8.11.3
[09/25/2018 11:47:30] info: [twx-studio:initializer] studio launched with the following arguments: _=[\\HCB-VNAS-E04.res.no.enterdir.com\E04_HOME01\113948\Personal], $0=..\..\..\..\..\..\Roaming\VuforiaStudio\studio-download.vuforia.io\dist\server\index.js
[09/25/2018 11:47:30] info: [twx-studio:initializer] studio dir:  C:\Users\113948\Documents\VuforiaStudio , home dir: C:\Users\113948\Documents
[09/25/2018 11:48:10] warn: [twx-studio:gitUtils] nodegit is not installed.
[09/25/2018 11:48:10] ar-extension version 8.3.3.3744 (1.29.1278)
[09/25/2018 11:48:19] info: [twx-studio:versionCheck] Version Check will use the update location: https://studio-download.vuforia.io/downloads/Studio.application
[09/25/2018 11:48:19] info: [twx-studio:index] Studio Ready: listening on 127.0.0.1:3000
[09/25/2018 11:48:19] Status Message:
Is it an issue that the nodegit is not installed?
tmccombie
(To:Petter)
Hi Petter, Are you using Google Chrome as your browser? http://localhost:3000/ is the correct URL for launching Studio. At this time, only Chrome is supported. Other browsers may not show the Studio homepage.
mgoel
(To:tmccombie)
@Petter
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
