Vuforia Studio "Validate" problem
CharlesWei_TW
6-Contributor
Cannot "Publish" to Vuforia Experience.
Below is the error message :
[2019-06-03T05:27:16.473Z] error: [twx-studio:proxy] Proxy error { Error: connect ETIMEDOUT 10.76.68.192:443
    at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1097:14)
  errno: 'ETIMEDOUT',
  code: 'ETIMEDOUT',
  syscall: 'connect',
  address: '10.76.68.192',
  port: 443 } null 200
[2019-06-03T05:27:16.474Z] error: [twx-studio:proxy] twx server proxy error...
[2019-06-03T05:27:16.474Z] error: [twx-studio:proxy] connect ETIMEDOUT 10.76.68.192:443
GET /ExperienceService/viewcommandhost 500 42130.133 ms - -
GET /api/switch 200 1.497 ms - -
[2019-06-03T05:27:53.491Z] error: [twx-studio:auth:oauthHandler] connect ETIMEDOUT 10.76.68.192:443
GET /api/switch 200 1.864 ms - -
[2019-06-03T05:28:14.494Z] error: [twx-studio:proxy] Proxy error { Error: connect ETIMEDOUT 10.76.68.192:443
  errno: 'ETIMEDOUT',
  code: 'ETIMEDOUT',
  syscall: 'connect',
[2019-06-03T05:28:14.495Z] error: [twx-studio:proxy] twx server proxy error...
[2019-06-03T05:28:14.495Z] error: [twx-studio:proxy] connect ETIMEDOUT 10.76.68.192:443
GET /ExperienceService/viewcommandhost 500 42010.524 ms - -
[2019-06-03T05:28:17.920Z] error: [twx-studio:auth:oauthHandler] connect ETIMEDOUT 10.76.68.192:443
GET /api/validate 500 42010.724 ms - 38
GET /api/switch 200 1.210 ms - -
POST /api/unpublish/ - - ms - -
GET /api/projectTemplates 304 1.573 ms - -
[2019-06-03T05:29:45.229Z] info: [twx-studio:versionCheck] version check complete 8.4.3.4381 8.4.3.4381 true
GET /api/version/check 304 948.432 ms - -
[2019-06-03T05:29:58.344Z] error: [twx-studio:auth:oauthHandler] connect ETIMEDOUT 10.76.68.192:443
GET /api/switch 200 1.648 ms - -
[2019-06-03T05:30:21.991Z] error: [twx-studio:auth:oauthHandler] connect ETIMEDOUT 10.76.68.192:443
POST /api/unpublish/ 500 42041.520 ms - 38
6 REPLIES 6
It seems the proxy setup cannot be reach and a timeout occurs.
  • What do you have as settings ?
  1. in Vuforia Home page > ... buttons
  2. In the popup menu, in Settings menu
  3. In the Settings dialogbox, what are the values for the fields: Proxy Server, Proxy User and Proxy Password
  • In Command Prompt, are you able to ping this address 10.76.68.192 ?
Thanks in advance for your feedback.
Best regards,
Samuel
CharlesWei_TW
6-Contributor
(To:sdidier)
I cannot ping 10.76.68.192.
In your second screenshot, it is strange to have the error message Failed to authorize experience service.
I have checked this URL in my web browser at PTC.
I have a Gitlab logo with 404 error.
Best regards,
Samuel
CharlesWei_TW
6-Contributor
(To:sdidier)
H:i, Samuel,
Q:What happens when clicking in the Validate button?
A: About 10 seconds, I got the results like this picture.
Q:What happens when pinging this server npjtwkiw.pp.vuforia.io ?
A: I cannot ping this website. 100% lost......
Q: In a Web Browser, what is the result of this URL https://npjtwkiw.pp.vuforia.io/ExperienceService/ping ?
A: I just got an error message!!!
Thank you for your help!
It seems the server who hosts Vuforia Experience Service is not running at all or it is not reachable.
  • Can you access to it physically to check if it is running ?
Best regards,
Samuel
CharlesWei_TW
6-Contributor
(To:sdidier)
Hello, Samuel,
The server hosts Vuforia Experience Service is not running at all.
So I cannot use it.
