This error keeps coming up and will not allow me to publish.
Thank you for the help! It turned out that my firewall was blocking Vuforia Studio from entering my files. All is working fine now.
Maybe you have insufficient rights for that directory. I would try creating a file in that folder.
yes u have to switch off the firewall while installing and using vuforia
