Vuforia View Error Hololens
Milliau
6-Contributor
Hey,
I have trouble with my HOlolens experience. I created it new to solve it but this doesn't help folllowing Errors i found in the Logs:
2019-03-26T12:00:16.108+01:00 [Error] VuforiaHandler - Cannot reset device tracker, tracker is null.
2019-03-26T12:00:16.109+01:00 [Information] ScanMode - Starting scanning mode.
2019-03-26T12:00:16.110+01:00 [Error] MainPage - Navigating Starting for [null]
2019-03-26T12:00:16.111+01:00 [Error] MainPage - Clearing the ms-local-stream resolver.
2019-03-26T12:00:16.112+01:00 [Information] default - Reseting VuforiaPlugin
Has someone solved this problem?
I created the information with Vuforia Studio
Thanks Milliau
Hi @Milliau,
is this issue the same as described in the post  - means issue occurs with the same Studio project?
Or is a different issue with a new project?
