I am seeing that the experience is pretty unstable even when the FPS is more than 30, it starts to flicker.
Also the model starts to follow the screen and tilts at different orientation which is not the desired result.
Let me know if there is something that can be done to address this.
Avinash
Hi Avinash,
How big is the model? Does it have a lot of polygons or parts?
Hi Tara,
It is a small Valve Assembly with less than 20 components.
Avinash
Hi
I have the same problem, however I am using a large model. Even when i download the experience the models turn and I loose association with the thingmark.
I have also been seeing a lot of unstable experiences recently. Its like my extended tracking isnt working properly even though that options has been selected.
