This is my first go at writing a script in Vuforia so I would appreciate the help in where I am going wrong. I have about 8 part models and I would like to toggle them on/off with a previous and next button in order to run through a sequence. This is what I have but I'm struggling with tying in the steps to the button functions.
// Increment Step when NEXT button is pressed
$scope.pressNextButton = function() {
currentStep = parseInt($scope.app.params[currentStepParam], 10);
if (currentStep < maxStep && !playing) {
$scope.app.params[currentStepParam] = currentStep + 1;
} else {
$scope.show(buttonAnimInProgress);
$timeout(function() {
$scope.hide(buttonAnimInProgress);
}, 2500);
currentlyShowingNextButton = $scope.app.params[showNextButtonParam];
$scope.hideNextButtons();
}, 50);
if (currentlyShowingNextButton) {
$scope.showNextButtons();
}, 2500);
// Return to previous Step when BACK button is pressed
$scope.pressBackButton = function() {
var currentlyShowingNext = $scope.app.params[showNextButtonParam];
if (currentStep > minStep && !playing) {
$scope.app.params[currentStepParam] = currentStep - 1;
} else {
}, 2500);
}, 50);
}, 2500);
// STEP FUNCTIONS
$scope.$on("currentStepParam", () =>
let currentStep = $scope.getCurrentStep("CowlModel")
if (currentStep == 1)
$scope.view.wdg['Damaged Panel']['visible'] = true;
$scope.view.wdg['Cleaned Panel']['visible'] = false;
$scope.view.wdg['Filler']['visible'] = false;
$scope.view.wdg['1st Ply']['visible'] = false;
$scope.view.wdg['2nd Ply']['visible'] = false;
$scope.view.wdg['3rd Ply']['visible'] = false;
$scope.view.wdg['Outer Ply']['visible'] = false;
$scope.view.wdg['Cowl - Repaired']['visible'] = false;
else if (currentStep == 2)
$scope.view.wdg['Damaged Panel']['visible'] = false;
$scope.view.wdg['Cleaned Panel']['visible'] = true;
else if (currentStep == 3)
$scope.view.wdg['Filler']['visible'] = true;
else if (currentStep == 4)
$scope.view.wdg['1st Ply']['visible'] = true;
else if (currentStep == 5)
$scope.view.wdg['2nd Ply']['visible'] = true;
else if (currentStep == 6)
$scope.view.wdg['3rd Ply']['visible'] = true;
else if (currentStep == 7)
$scope.view.wdg['Outer Ply']['visible'] = true;
else if (currentStep == 😎
$scope.view.wdg['Cowl - Repaired']['visible'] = true;
else
$scope.app.params[showNextButtonParam] = true;
Larry,
Initially from a code observation
your pasted code currentStep = parseInt($scope.app.params[currentStepParam], 10);to access the params property
you would use $scope.app.params.currentStepParam
and maybe you would do
let currentStep = 0;
if ($scope.app.params.currentStepParam != null && $scope.app.params.currentStepParam != "") {
currentStep = parseInt($scope.app.params.currentStepPara)
} else {
currentStep = 1;
This should be
$scope.app.setWidgetProp('3rd Ply', 'visible', false)
or
$scope.view.wdg['3rd Ply'].visible' = false;
Also
There is always different ways to achieve this - many is Creo Illustrate to define a sequence of steps and the use the events to listern to next step click binding but you have 8 models and I'm not sure where they are etc.
Hope this helps
