VuforiaStudio请求服务器数据
FY_10283333
2-Explorer
提供一段js代码,满足以下条件:1、请求服务器数据 2、在vuforia studio的Home.js里面使用3.请求的数据如何解析后绑定不同的文本显示在2D  UI上
7 REPLIES 7
Hi @FY_10283333,
Thank you for your question regarding the JavaScript code for Vuforia Studio. To better assist you, please add more context to your topic.
Possibly on the below points?
  1. Could you specify the type of data you are requesting from the server and the API endpoint you are using?
  2. Are there any specific requirements or constraints for using the code within the Home.js file in Vuforia Studio?
This information will help the community members understand your requirements more clearly and provide a more accurate and helpful response.
Vivek N
Community Moderation Team.
你好
    1.请求到的数据类型是Json字符串
    2.特定要求没有,就是注意一下请求的链接错误,超时等给出提示即可
Best Regards!
Hi @FY_10283333 ,
To your points:
Provide a piece of js code that meets the following conditions:
Your Question 1. request server data - what kind of server /Thingworx server . And what kind of data ?
Answer: Currently because there is CORS resticion you could contact only as server located on the same domain The code will differs depending on that , what kind of server object you need to access . PTC supports only server request where data is requested but access depend on that what is the server database /Things and properties what need to be requested and if there are specific requirements.
2. use inside Home.js in vuforia studio -
Answer any JS code could be used there so far It is supported on the mobile platforms
3. how the requested data is parsed and then bound to different text to be displayed on the 2D UI
- you do not need to parse /that what  in terms of Javascript/  but to convert it  to string (JSON.stringify() when it is a json object) or .toString() methoded if you have an object which supports that method and then you could display it on widget wich support the text property
example:
$scope.myText="any text there";
$scope.setWidgetProp("myLabel-1","text",$scope.myText);
你好
就像MQTT服务器,在同一个局域网内,但不经过Thingworx,直接在Home.js里面去写脚本来连接服务器获取消息,怎么写
谢谢
That could work but only when the MQTT server is running on the same server where you installed the Experience Service. The best will be when you have some MQTT server which could be access via REST API so that you can use the standard rest API in Home.js and you do not need to use any additional libraries. I think the best approach is to install every thing in node.js server on the same location where you Experience Service is running . So you can install there also you MQTT clients etc and integrate in a WebServer which you can access then vom Studio where the standard REST api calls are supported.  But all that is is not part of the supported functionality. I di not have examples for that - Possibly somebody else could provide a help
Here is samples for the node.js server npm - MQTT.js  e.g. what I found when I searched
https://www.npmjs.com/package/mqtt#example
https://stackoverflow.com/questions/58852141/showing-mqtt-response-on-a-node-server-api
https://stackoverflow.com/questions/66506976/sending-mqtt-data-via-api
https://iot.stackexchange.com/questions/5828/how-to-make-a-mqtt-broker-and-a-rest-api-communicate
Also a test in chat AI toolsDeepSeek  whiere simple I tested , did provide the following resuts (below):
Could you provide a code what access a MQTT brocker and will provide an node.js server where I could request the MQTT invormaton via REST api requests
Here's a Node.js example that connects to an MQTT broker and provides REST API endpoints to access MQTT information:
javascript
Copy
require('dotenv').config();
const express = require('express');
const mqtt = require('mqtt');
const cors = require('cors');
// Initialize Express app
const app = express();
const port = process.env.SERVER_PORT || 3000;
// MQTT Configuration
const mqttUrl = process.env.MQTT_URL || 'mqtt://broker.hivemq.com';
const mqttTopics = process.env.MQTT_TOPICS ? process.env.MQTT_TOPICS.split(',') : ['test/topic'];
const mqttOptions = {
  clientId: `mqtt_${Math.random().toString(16).substr(2, 8)}`,
  clean: true,
  connectTimeout: 4000,
  reconnectPeriod: 1000,
// Store received MQTT messages
const mqttDataStore = {};
// Connect to MQTT Broker
const mqttClient = mqtt.connect(mqttUrl, mqttOptions);
mqttClient.on('connect', () => {
  console.log('Connected to MQTT Broker');
  mqttClient.subscribe(mqttTopics, (err) => {
    if (!err) {
      console.log(`Subscribed to topics: ${mqttTopics.join(', ')}`);
mqttClient.on('message', (topic, message) => {
  console.log(`Received message on ${topic}: ${message.toString()}`);
  mqttDataStore[topic] = {
    message: message.toString(),
    timestamp: new Date().toISOString()
mqttClient.on('error', (err) => {
  console.error('MQTT Error:', err);
// Express middleware
app.use(cors());
app.use(express.json());
// REST API Endpoints
app.get('/api/mqtt', (req, res) => {
  res.json({
    status: 'success',
    data: mqttDataStore
app.get('/api/mqtt/:topic', (req, res) => {
  const topic = req.params.topic;
  if (mqttDataStore[topic]) {
    res.json({
      status: 'success',
      data: mqttDataStore[topic]
  } else {
    res.status(404).json({
      status: 'error',
      message: 'Topic not found'
// Start server
app.listen(port, () => {
  console.log(`REST API server running on port ${port}`);
process.on('SIGINT', () => {
  mqttClient.end();
  process.exit();
To use this code:
  1. Install required dependencies:
bash
Copy
npm install express mqtt dotenv cors
  1. Create a .env file with your configuration:
env
Copy
MQTT_URL=mqtt://your-broker-url
MQTT_TOPICS=topic1,topic2,topic3
SERVER_PORT=3000
  1. Start the server:
bash
Copy
node server.js
Key features:
  • Connects to MQTT broker and subscribes to specified topics
  • Stores last received message for each topic
  • Provides REST API endpoints:
    • GET /api/mqtt - Get all stored MQTT messages
    • GET /api/mqtt/:topic - Get message for specific topic
  • Handles MQTT connection errors and reconnections
  • Uses environment variables for configuration
Example usage with curl:
bash
Copy
# Get all messages
curl http://localhost:3000/api/mqtt
# Get specific topic
curl http://localhost:3000/api/mqtt/your/topic
To test with MQTT publishing (using mosquitto_pub):
bash
Copy
mosquitto_pub -h broker.hivemq.com -t "test/topic" -m "Hello World"
Potential improvements you could add:
  • Authentication for both MQTT and REST API
  • History storage (not just last message)
  • WebSocket support for real-time updates
  • QoS configuration for MQTT
  • Message validation
  • Rate limiting for API endpoints
Remember to:
  • Keep your MQTT broker secure
  • Handle sensitive data appropriately
  • Add proper error handling for production use
  • Implement proper CORS configuration for your needs
  • Add request validation for the API endpoints
你好
Thank you very much!
Best regards!
Hello @FY_10283333,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
