提供一段js代码,满足以下条件:1、请求服务器数据 2、在vuforia studio的Home.js里面使用3.请求的数据如何解析后绑定不同的文本显示在2D UI上
Hi @FY_10283333,
Thank you for your question regarding the JavaScript code for Vuforia Studio. To better assist you, please add more context to your topic.
Possibly on the below points?
This information will help the community members understand your requirements more clearly and provide a more accurate and helpful response.
Vivek N
Community Moderation Team.
你好
1.请求到的数据类型是Json字符串
2.特定要求没有,就是注意一下请求的链接错误,超时等给出提示即可
Best Regards!
Hi @FY_10283333 ,
$scope.myText="any text there";
$scope.setWidgetProp("myLabel-1","text",$scope.myText);你好
就像MQTT服务器,在同一个局域网内,但不经过Thingworx,直接在Home.js里面去写脚本来连接服务器获取消息,怎么写
谢谢
That could work but only when the MQTT server is running on the same server where you installed the Experience Service. The best will be when you have some MQTT server which could be access via REST API so that you can use the standard rest API in Home.js and you do not need to use any additional libraries. I think the best approach is to install every thing in node.js server on the same location where you Experience Service is running . So you can install there also you MQTT clients etc and integrate in a WebServer which you can access then vom Studio where the standard REST api calls are supported. But all that is is not part of the supported functionality. I di not have examples for that - Possibly somebody else could provide a help
Here is samples for the node.js server npm - MQTT.js e.g. what I found when I searched
https://www.npmjs.com/package/mqtt#example
https://stackoverflow.com/questions/58852141/showing-mqtt-response-on-a-node-server-api
https://stackoverflow.com/questions/66506976/sending-mqtt-data-via-api
https://iot.stackexchange.com/questions/5828/how-to-make-a-mqtt-broker-and-a-rest-api-communicate
Also a test in chat AI toolsDeepSeek whiere simple I tested , did provide the following resuts (below):
Could you provide a code what access a MQTT brocker and will provide an node.js server where I could request the MQTT invormaton via REST api requests
Here's a Node.js example that connects to an MQTT broker and provides REST API endpoints to access MQTT information:
require('dotenv').config(); const express = require('express'); const mqtt = require('mqtt'); const cors = require('cors'); // Initialize Express app const app = express(); const port = process.env.SERVER_PORT || 3000; // MQTT Configuration const mqttUrl = process.env.MQTT_URL || 'mqtt://broker.hivemq.com'; const mqttTopics = process.env.MQTT_TOPICS ? process.env.MQTT_TOPICS.split(',') : ['test/topic']; const mqttOptions = { clientId: `mqtt_${Math.random().toString(16).substr(2, 8)}`, clean: true, connectTimeout: 4000, reconnectPeriod: 1000, }; // Store received MQTT messages const mqttDataStore = {}; // Connect to MQTT Broker const mqttClient = mqtt.connect(mqttUrl, mqttOptions); mqttClient.on('connect', () => { console.log('Connected to MQTT Broker'); mqttClient.subscribe(mqttTopics, (err) => { if (!err) { console.log(`Subscribed to topics: ${mqttTopics.join(', ')}`); } }); }); mqttClient.on('message', (topic, message) => { console.log(`Received message on ${topic}: ${message.toString()}`); mqttDataStore[topic] = { message: message.toString(), timestamp: new Date().toISOString() }; }); mqttClient.on('error', (err) => { console.error('MQTT Error:', err); }); // Express middleware app.use(cors()); app.use(express.json()); // REST API Endpoints app.get('/api/mqtt', (req, res) => { res.json({ status: 'success', data: mqttDataStore }); }); app.get('/api/mqtt/:topic', (req, res) => { const topic = req.params.topic; if (mqttDataStore[topic]) { res.json({ status: 'success', data: mqttDataStore[topic] }); } else { res.status(404).json({ status: 'error', message: 'Topic not found' }); } }); // Start server app.listen(port, () => { console.log(`REST API server running on port ${port}`); }); process.on('SIGINT', () => { mqttClient.end(); process.exit(); });
To use this code:
Install required dependencies:
npm install express mqtt dotenv cors
Create a .env file with your configuration:
MQTT_URL=mqtt://your-broker-url MQTT_TOPICS=topic1,topic2,topic3 SERVER_PORT=3000
Start the server:
node server.js
Key features:
Connects to MQTT broker and subscribes to specified topics
Stores last received message for each topic
Provides REST API endpoints:
GET /api/mqtt - Get all stored MQTT messages
GET /api/mqtt/:topic - Get message for specific topic
Handles MQTT connection errors and reconnections
Uses environment variables for configuration
Example usage with curl:
# Get all messages curl http://localhost:3000/api/mqtt # Get specific topic curl http://localhost:3000/api/mqtt/your/topic
To test with MQTT publishing (using mosquitto_pub):
mosquitto_pub -h broker.hivemq.com -t "test/topic" -m "Hello World"
Potential improvements you could add:
Authentication for both MQTT and REST API
History storage (not just last message)
WebSocket support for real-time updates
QoS configuration for MQTT
Message validation
Rate limiting for API endpoints
Remember to:
Keep your MQTT broker secure
Handle sensitive data appropriately
Add proper error handling for production use
Implement proper CORS configuration for your needs
Add request validation for the API endpoints
你好
Thank you very much!
Best regards!
Hello @FY_10283333,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
