Hi, I'm wondering whether is a way to download project from "Experience Server" to local Thingworx Studio.
I created a project, published it to server, on one PC, but I need to modify it on another laptop. Is there a way that I can download it from server?
Btw, is there a CURL/REST API reference for Thingworx Studio?
Many thanks
Yifu
Hej,
not easily, as the source is not equal to the published app.
if you still have laptop 1 - just copy the folder from Documents/Thingworx Studio/ Projects folder..
I'm currently working on it as well.
martin
Many thanks
Yifu
Hej,
martin
Many thanks
Yifu
Thanks, Martin Wassmann, I will take the project folder with me for now! Hope one day there will be a easier way to backup the source.
Thanks for the post, giri, you mentioned, update/delete call in it, is there a sample for getting published projects?
You should use as source versioning system as for now.... e.g. git.
Sure, I would, after I get over the trial & error period. Thanks
As of now, you can get the list of existing projects (published) using curl/postman. But not the project files.
FYI, follow this post in studio community- Re: Publishing the experience programmatically
is there a way to download the files somehow directly from the Experience Service?
Background: Local files of an experience are not available anymore; but we need to modify the experience.
Raphael
