Hi there,
I have 2 Thing properties:
Bindings in Vuforia Studio are:
property | widget | application parameters |
testJson | ['label-json'].text | testJson |
testString | ['label-string'].text | testString |
When I console.log $scope.view.wdg['wdg-id'].text and $scope.app.params['params'] respectively.
Widgets can deliver data flawlessly, but Application Parameters do not.
console.log($scope.app.params.testJson)
>>> [object object] (type: string)
console.log($scope.app.params.testString)
>>> undefined (type: undefined)
So, what's the limitation of Application Parameters? What is the Best Practice of Application Parameters?
Help doesn't provide much help.
https://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FAppAndDevicePropPanel.html
Thanks in advance.
Notes:
Thing Property testJson (Base Type: JSON) | result |
via Label Widget ['label-json'].text | everything works, type Object |
via Application Parameters $scope.app.params.testJson | become a String "[object Object]", length 15 |
Thing Property testString (Base Type: String) | result |
via Label Widget ['label-string'].text | type String, could work with JSON.parse() |
via Application Parameters $scope.app.params.testString | Must avoid double quotation mark (") in the Thing property, therefore, JSON.parse() is not feasible. |
Hello Clark,
The solution is to parse data from Application Parameter to a know type/object.
Here in your example in a JSON type.
We can find example in these posts in PTC Community :
https://community.ptc.com/t5/Vuforia-Studio/Select-Widget-default-value/m-p/611653
https://community.ptc.com/t5/Vuforia-Studio/How-to-use-List-in-ThingWorx-Studio/td-p/522911
Best regards,
Samuel
Hi, Samuel
Thanks you for replying.
Frankly speaking, the question has been simplified.
It is a Thing on Thingworx which has 80 properties (boolean) need to be presented in Vuforia Studio.
Rather than binding 80 Widgets in Vuforia Studio with 80 properties on Thingworx. (update every 3sec)
I use Thingworx Service to generate a JSON (name: allStatus), than bind the allStatus to Vuforia Studio.
If allStatus binds to a Application Parameters:
If allStatus binds to a Vuforia Studio Label Widget:
>>> everything works
In other words, I can get the job done with a Widget, just wondering if it is feasible without Widget.
Best Regards,
ClarK
After doing some test,
A double quotation mark (") is in a Thingworx Thing Property String would cause Vuforia Studio Application Parameter issue.
Therefore, avoid " in a Thingworx Thing Property String when binding to Vuforia Studio Application Parameter is required.
In some cases, you can adapt the value or check it using the JSON.parse() or JSON.stringify() in the filter section of the binding.
example in the filter:
return JSON.parse(value);
as it was mentioned in the post :https://community.ptc.com/t5/Vuforia-Studio/How-to-use-List-in-ThingWorx-Studio/m-p/522911#M497
In some case when you are not sure what the value is - in this case you use some construct like (redudnat check):
return JSON.parse(JSON.stringify(value));
converting first to string and then back to object hoping that this will check/ fix the syntax - of course this should be tested in the particular situation - e.g.
$scope.app.params["ItemList"] = "";
$scope.app.params["ItemList"] = JSON.parse(JSON.stringify(obj));//check
as metioned in https://community.ptc.com/t5/Vuforia-Studio/How-to-create-2D-3D-components-using-Javascript-from-a-array-of/m-p/662936
... or
return angular.fromJson(value);
as mentioned in: https://community.ptc.com/t5/Vuforia-Studio/Can-t-use-more-than-one-sequence-animation-in-a-single/m-p/518235#M2355
Hi, @RolandRaytchev
Things are, if Thingworx Thing Property (testJson, Base Type: JSON) is bond to a Vuforia Studio Widget (Label), everything works fine. Data in the Vuforia Studio Widget is Object already, No JSON.parse() needed. Therefore, no need for using Filter.
Nevertheless, if the same Thing Property testJson is bond to a Vuforia Studio Application Parameters (nemed testJson), Data become a String "[object Object]", with length 15, not 243. Which means that JSON.parse() couldn't do anything to it.
Is it possible to Bind a Thingworx Thing Property (Base Type:JSON) to a Vuforia Studio Application Parameters and still preserve the Data it that Property?
Best regards,
ClarK
Notes:
Yes , I could reproduce this issue. Strange. I think this seem to be related that there is some delay when the JSON service is called so that when the parameter is initilized . For example when I test the following:
In this case the issue could be reproduced but when some times later we click a button (button JS Box will call test() ) This will set the data to the parameter - then this works fine. Following sample code:
$scope.test=function() {
console.warn($scope.app.params['TESTJSON']);
$scope.setWidgetProp('textArea-1','text',$scope.app.params['TESTJSON']);
So now when we click the button -> data is passed fine to the applicaiton parameter test and the parameter has also binding to the widget and the value is passed correctly form the parameter to the widget. Therefore I susspect that this is some issue based on service delay where the value is not converted and passed correctly
So if you want to set a parameter with a JSON data which comes form TWX service -> the following workaround could be use /one possible option :
// this function will set the data to the parameter
// the function is called after the view is entered
$scope.init=function() {
let result=$scope.app.mdl['TestRepository'].svc['testJson'].data;
console.warn(result)
$scope.app.params['TESTJSON']=JSON.stringify(result);
$scope.$applyAsync();
//event which will call the function with a delay on start
$scope.$on('$ionicView.afterEnter', function() {
$timeout(() => {
$scope.init();
},500)
// this will set manually the value form parameter to widget
Here the values are set with some delay
Thanks for replying and confirming the issue.
I guess it is easier to Bind Thingworx Thing Property to a Vuforia Studio Widget for further usage.
Even it would be a bit more messier in the Views Panel (with Widgets that bond to Thing Properties).
