When i scan the thingmark and bring up the experience,and then walk away/around from the thingmark, the model also follows.It doesnt stick to its location. It doesnt zoom out even when you are significantly away from the Thingmark..
Did you try unchecking the 'Extended Tracking' property under 3D container widget?
