blinking of a 3d image
potatochips
How to create a 3d image that is blinking?
You would probably need to use an $interval timer for this, along these lines:
$scope.blinkInterval = 0;
$scope.blinkImage = function(id) {
    var current = $scope.view.wdg[id].visible;
    if (current == undefined) { current = true;}
    $scope.setWidgetProp(id, "visible", !current);
$scope.startBlink = function() {
    $scope.blinkInterval = $interval($scope.blinkImage, 1000, 0, true, "3DImage-1");
$scope.stopBlink = function(id) {
  $interval.cancel($scope.blinkInterval);
angular.element(document).ready($scope.startBlink);
You can use the $scope.stopBlink() function to stop the image from blinking, either in response to an event or attached to a UI control if you want.
If you want to control when the blinking starts, simply remove the last line and add a call to $scope.startBlink() when you want it to start blinking.
