hi!
I have an experience that works for tablets, how to change this tablet experience in hololens?
thank you.
You will have to create a new HoloLens specific project and then copy/paste the project information from one to the other.
I try and I'll let you know. thank you
Hello! I tried, now I can get a previsualization, but when I publish it, the hololens show me nothing, I'm confused. to note that in the preview, so that the experiment works it would have to press a plays button every time, I think that the problem comes from the. how to integrate this button into the hololens experience? thank you
Instead of buttons, you can use application events (e.g. double tap) to initiate playing of a sequence within a hololens project. Just bind the event to the model 'play all' service.
hi,
my experience works in the preview, but when I publish it I do not see my experience.
do you have an idea?
he asks me to scan my thingmark, which I do but nothing appears, I am confused.
thank you in advance
Ensure that you are scanning the same ThingMark you published to. You can check in the Experiences tab of the project.
Do you have your Experience URL within View set to a different Experience Service?
how to check it?
Hello, I am enclosing you with my journal, and you will probably understand my problem better than I do. I see warn in the log! a syntaxError but I do not know how to do it. could you please help me. Thank you.
