error in install vuforia studio setup
emmanuel001
Hi everybody, I'm trying to install vuforia studio but when I run the setup I get the following window
I check the log file and I get the following
Why can not I install studio? What's going on? thanks for your help
dupatel
(To:emmanuel001)
@emmanuel001  It seems your firewall or network is blocking download of required Studio installer  files. Could you please confirm if you get the Studio.application file when you open the URL directly on the browser- https://studio-download.vuforia.io/downloads/Studio.application
Also, if you get the .application file then click and review the install.log generated  in location as mentioned in the screenshot.
-Durgesh
2 REPLIES 2
dupatel
(To:emmanuel001)
-Durgesh
Thanks for you help, is correct and functional.
