experience service url is not validating
Deepak_P
3-Visitor
experience service url is not validating.
Thanks and Regards,
Deepak P
10 REPLIES 10
dupatel
(To:Deepak_P)
@Deepak_P Could you please share ES URL and provide detail of the error message you are getting ? Where you able to validate it earlier and it stopped working now?
-Durgesh
I am not able to validate from the beginning itself.
We installed trail version 3 days back and trying to configure.
dupatel
(To:Deepak_P)
@Deepak_P Could you please make sure your Firewall or network is not blocking the ES URL ? Also, share Studio application logs to review the exact cause of issue.
-Durgesh
All the pop ups are allowed and nothing is blocking. I am not able to get the log report.
Even in the welcome e-mail, I dont see an URL
Deepak P
Please find the error report
[2018-10-26T10:41:57.734Z] error: [twx-studio:auto_configure] undefined GET https://studio.vuforia.com/api/v1/service_details Unable to retrieve service details. Request failed. { Error: connect ETIMEDOUT 52.72.238.51:443
at Object._errnoException (util.js:992:11)
at _exceptionWithHostPort (util.js:1014:20)
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1186:14)
code: 'ETIMEDOUT',
errno: 'ETIMEDOUT',
syscall: 'connect',
address: '52.72.238.51',
port: 443 }
[2018-10-26T10:41:57.737Z] error: [twx-studio:index] unhandledRejection Unable to retrieve service details. Request failed.
GET /api/autoConfigure 500 21074.376 ms - 35
any updates on this? We are loosing the working days to test the trial?
dupatel
(To:Deepak_P)
@Deepak_P From the logs, it is clear that your connection request is getting time out which could be due to IP or Port getting blocked (address- 52.72.238.51 , port 443 ).  Suggest to please try login outside your corporate/existing network and switch using mobile/home connection to see if it helps.
Meanwhile, I am also checking internally to do quick checks on your Trial instance.
-Durgesh
I have to use it in office only and it is desktop. Please look into it.
Any updates on this now?
If I am not able to publish the experience it is of no use to me. I am loosing the time and now left with only 20 days of trail. it is like waste of trial installation.
Please look into it
dupatel
(To:Deepak_P)
@Deepak_P I have emailed you the details of your Experience Service and ThingMark ID.
Please make sure your organization network do not block Experience Service URL and allows communication with port 8443 & 443.
-Durgesh
