facing problem while uploading file which is having size more than 100mb
Re: facing problem while uploading file which is having size more than 100mb
Thank you for reply.
I have tried to launch pvz optimiser but could not able to write a code as it runs that pvaroptimizer.exe and screen went it's doesn't wait for writing the code.
Thank you
Please follow these steps :
  1. In Windows tray, in Vuforia Studio icon, right click
  2. In popup menu, select CAD Tool shell
  3. In Command prompt, run command line for pvaroptimizer.exe
Best regards,
Samuel
Where should i write a code kindly let me know for optimizing file size.
Thank you
Hello
please find here attached snapshot of error while running code.
Thank you
  • Did you follow steps provided in my previous post ?
In your screenshot, the root folder is not this one :
%USERPROFILE%\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\cad-import-filters\import_filters\bin
Please follow these steps in Command prompt:
  1. echo %USERPROFILE%
  2. CD <to replace by value reported at step 1>AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\cad-import-filters\import_filters\bin
  3. Run the cadoptimizer command again
Best regards,
Samuel
In right click i haven't find any pop up for CAD shell.
Thank you
In the popup menu, it is this menu.
My screenshot is in French but it is similar in English or other supported language in Vuforia Studio.
  • What do you have in your workstation ?
Best regards,
Samuel
Topics available:
AR/VR for Data Optimization AR/VR for Security and Control AR/VR for Inspection
