Goodmorning everyone,
the setup of the AR experience I'm working on is based on a license that includes Thingworx, ptc navigate and windchill. All working and connected to Vuforia.
I need to build an application that produces the following actions:
1. load a pvz model;
2. Once I have clicked on a component in the model, I must be able to trace the code of the clicked component
Regarding point 2 it is not clear to me how to interact with Thingworx, so as to go back to:
- production order
- assembly code
- part code
passing through Windchill.
Anyone have any ideas on how to setup the project in Thingworx?
Hi @leonardosella ,
I think there is no direct option to access the Windchill data e.g. REST API or windchill custom API directly from Vuforia because of CORS restriction . The only way I think is to use Thingworx get/ set service where you can delegate the tasks for getting or setting data of Windchill. This means from the Vuforia Studio point of view , I think , is only this option what we have. Therefore I believe it is better if you address your question additional to the IOT PTC community groups:
https://community.ptc.com/t5/ThingWorx-Developers/bd-p/twxdevs
https://community.ptc.com/t5/Thingworx-Navigate/bd-p/thingworxnavigate
May be someone looking in Vuforia community has also the knowledge to answer the question how to setup a service for accessing windchill but I believe it more probable that such knowledge is available in the IOT community.
If we have the option to access windchill via rest API there is a extensions in TWX which could performs such call. May be exist some services as part the Navigate extension which could be used for this task, but here I hope some expert on this area could provide more help
