how to get stepsname/sequencenames/stepdescription from pvz file (saved in repository in thingworx)
MA8731174
Hello Community,
         I have installed the extension  CreoViewRWExtension in thingworx platform and it does show a lot of information about pvz file in thingworx but i am unable to get the stepsname and stepsdescription. It does shows a sequence names though and a lot of other stuff. here is the extension link:
EXTENSION
https://github.com/mvonhasselbach/CreoViewRWExtension/tree/master
I have already raised an issue in the community the link is as below for further clearance:-
THINGWORX QUERY
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-extension-to-compress-videos/m-p/972096#
Please let me know how can i achieve that.
4 REPLIES 4
@RolandRaytchev  do you have please any idea about it? My pvz file i have saved in file repository in thingworx and i just want info now about step name, sequence name from it. this extension which i have installed is so good but it does not show me this info there.
Hi @MA8731174,
Thank you for your question!
Best regards,
Catalina
PTC Community Moderator
PTC
I don't believe the extension provides that info. You can access the pvz in the repo and unzip and look for pvi's and look inside for
galaxy_3di:sequence
