we are facing issue in viewing cut section file in vuforia studio. how to create it in simple way?
As i have assembly containing 40 parts, its very difficult to do that?
I referred following links but that doesn't make sense as it will only increase the work of CAD part instead to studio?
https://community.ptc.com/t5/Vuforia-Studio/Re-how-to-add-section-view-in-studio/m-p/547578
still its manipulation. its doesnt seems the exact solution which i am seeking for
Hi @InfinityX ,
so far, I know the both link that you mention still mirrors the current functionality, there is no significant change.
Additionally you can check this Tech Tip "Section view or Clipping of model display in Vuforia Studio" ( new is last part using a x,y z clipping shader).
