While using the spatial target in Vuforia Studio, the models are not stable or are not rendering properly in HoloLens 2. Is there any suggestion to stabilise the model?
Hi @Milan_900 ,
2.) the second statement - is not rendering properly - what this means - transparence , color , visibility what is incorrect or still you meant that the position is wrong? - So the same as point 1.)
I think the best could be if you could provide an example project (the best), or at least some pictures or video and information about the project if there is specific usage relevant to the problem like javascript code or thingworx service etc. /relevant means that you observed that issue occurs only if specific configuration is used.
On my HL2 device I have many project with spatial target and I could not observe such behavior with old versions 9.12. I did not tested in 9.14 yet.
Thanks, BR
