I had previously published some small projects that I haven't had to edit or amend for a while. The associated ThingMarks for those couple of projects still work using ThingWorx View and now I need to work on them again, but unfortunately they do not show in the list of recent projects in Studio. Is there an easy way of getting access to these "hidden" projects?
Many thanks,
B
Brian, Are you able to see the desired project files under <Documents/user Home>/ThingWorx Studio/Projects/ location?
Hi Giri,
No, that was the first place I looked! The ThingMarks still work for these older wanted projects although the projects don't display in the Projects location as you indicate!
B
