Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Hi
i have created some sequences creo illustrate and i would like to play these in Thingworx studio.
In illustrate i have pressed publish and get i pvz. file, which i uploaded to studio .
But after i published i could not see the sequences ( i also made a play button ).
So i hope somebody can help me.
Thanks.
Alperen
on the model widget is a drop down for sequences. you can simply choose your sequence from here. No need for renaming, unzipping or manually adding of pvi files.
Hi Alperen,
Please follow the below steps to add a sequence to the 3D model:
Please follow the below steps to extract the PVI file from the resulting pvz file:
I have published a file from Creo Illustrate as a .pvz but have no luck getting ThingWorx to play the sequences after choosing the Sequence in Studio.
I am working with and learning Creo Illustrate 5.0 with the task of making sequences to be viewed in ThingWorx.
I have made a simple file for testing purposes and when the file is opened in ThingWorx Studio (8.2.2.3099) the Model shows up but it will not play the sequences.
Is there a setting or something special that needs to be done?
Hi Susan,
have you assigned a klick event, to start the animation? You can find a guide here:
If this doesn't work, I would try to load an example applikation like the helicopter. Now klick on preview and test if you can see the animations there. If it still won't play, then something must be wrong with your browser.
