I have been using ThingWorx Studio for around a week, it stopped working for what every reason. so i am trying to reinstall it. I seem to been having a problem reinstalling it.
Application cannot be started contact the application vendor. attached is the log file can any one help i was doing so well!
Message was edited by: Sushant Pandey moved to ThingWorx Studio Community
What happens if you download the URL in the log (via the browser) and install it via this file?
https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
You can also check out this article... it mentions some of the directories where (temp) files might be stored - maybe they are interfering with the new installation, so be sure to clean those directories out after de-installing Studio.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS251716
Hi Michael, I have tried using the link I seem to get the same problem as before.
Hi FITZ BENJAMIN, Could you please share the steps followed to reinstall ThingWorx Studio.
From the logs it seems that some file cannot be found and the activation failed.
I would recommend you to restart the Server after the uninstall.
Ankit Gupta
Hi Gupta;
I have followed the details for uninstalling ThingWorx information
emoved the ThingWorx folder from within document
I have attached the install log file
Any ideas?
Microsoft .NET Framework 4.5.2 is installed correctly?
(as it says "no install needed" I'd guess it is, but a confirmation on this will be helpful)
Update:
The current status of my problem.
Device Type :
Regards
FB
Hi
Has anyone solved this problem? I am getting similar problem. Studio working fine on Windows 10 and then it stopped working. That is the application launches correctly but then when I click to open (localhost), i get spining thingmark logo and waits forever.
I tried uninstall and reinstall Studio and same problem.
Any help appreciated.
Go to %userprofile%\AppData\Local\Apps and delete the 2.0 file. Reinstall the setup file and you will have access again.
Good luck,
Sabrina.
