I try install vuforia studio trial.
installation occur error.
could you please check my error?
ello,
The exception in the log file is :
[2019-04-23T06:02:02.110Z] error: [twx-studio:index] uncaughtException { Error: listen EACCES: permission denied 127.0.0.1:3000
at Server.setupListenHandle [as _listen2] (net.js:1253:19)
at listenInCluster (net.js:1318:12)
at GetAddrInfoReqWrap.doListen [as callback] (net.js:1451:7)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:61:10)
code: 'EACCES',
errno: 'EACCES',
syscall: 'listen',
address: '127.0.0.1',
port: 3000 } undefined
It is due that previous Vuforia Studio is still running or another application uses the port 3000.
Shutdown Vuforia Studio and software who are using this port 3000.
More details in this thread :
https://community.ptc.com/t5/Studio/Problem-with-installation/td-p/572489
Best regards,
Samuel
ello,
code: 'EACCES',
errno: 'EACCES',
syscall: 'listen',
Best regards,
Samuel
sorry..
I did not shut down vuforia.
After vuforia shutdown, I left the 3000 port and it was installed.
