Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I think you would be better served using a decal for what you are doing. Decals can be saved with the part.
How to apply an image or decal to a Creo Parametric model as a texture - EAC Tip of the Week (youtube.com)
The method you are using to add t...
View more
Thanks for the reply. It worked, but with a couple additional details:1) I did have to change my modelcheck_dir option in config.pro and copied the entire config folder to that personal directory where I have full rights by default.2) I had to rename...
View more
Hello EveryoneGood Evening, I am facing problem in logging properties there are some values which are repeating after I carry out the experience multiple times.PFA attached image in which arrows are shown on the readings which are repeating when I co...
View more
1. How can I search for each frequency range?For example I looked into the excel file and I saw that 1kHz begin from line 61536 and is ended at line 62560:
Therefore I extracted manually the respective range in Mathcad:
So, for...
View more
Check out this video on Creo "Sketcher" from PTC Application EngineersPresenters: Emily Pinto (Solution Consultant) and Ryan Butcher (Solution Consultant, Fellow)Original Date Presented: March 19, 2024 To dive deeper into the subject, check out Creo ...
View more
