Hi @SS_10698059
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Thanks for your response
so we have onr own custom rest api service , we need to call OOTB windchill rest api (checkout,update and checkin) from our custom rest service , we are generating authtoken and csrf token with same userID .
my main purpose is to reduce roundtrip time to perform update operation (checkout , update then check-in) at one place.
postman i am getting response when i m trying with oauth in url where passing same token and csrf which i am passing to the rest api
bellow error getting :
"HttpClientErrorException: Status Code: 403 FORBIDDEN, Response Body: <html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8"/>
<title>Windchill Error</title>
</head>
<body>
<tr valign="top">
<th align="right" scope="row">Request URI: </th>
<td>/Windchill/trustedAuth/servlet/odata/v7/MfgProcMgmt/CheckOutOperations</td>
<!-- General purpose Windchill error page, /wtcore/error.jsp -->
<h1>Windchill Error</h1>
<p style="font-size: large">
Contact your administrator for assistance.
Information for their reference follows.
<th align="right" scope="row">Message: </th>
<td>wt.licenseusage.licensing.LicensingException: Access is denied. You are not a registered Windchill user.</td>
For the userID you are using to connect, does the user exist in Windchill? Its reporting back that you are not listed as a user. Make sure that userID is in the Windchill LDAP and has a valid license assigned to it.
yes user is valid windchill user still facing this issue
Check out some of these articles which might be related. Let me know what you find.
https://www.ptc.com/en/support/article/CS343821?source=search
https://www.ptc.com/en/support/article/CS375103?source=search
I noticed you are using trustedAuth. Is the IP or host you are connecting from listed in the wt.properties as being a valid trusted host?
https://www.ptc.com/en/support/article/CS182327?source=search
Note, there are plenty of warnings about this configuration being deprecated but I have yet to see a replacement.
