The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
API to update classification node Display name and description through API.
prasad_RR
I am trying to update display name and Description of classification node throgh API.
Please suggest possible ways.
9 REPLIES 9
Just out of curiosity, how many nodes to you have to update? Why not just manually update them?
prasad_RR
(To:avillanueva)
we have a list of 400+ nodes which need to be created .
I have written a code which is able to create all node by reading excel in particular format. same is  shown in above screenshot .But struggling to find a api to update displayname and description.
Hi @prasad_RR ,
I also have the same scenario need to implement,
need to create classification nodes and update its constraints in bulk by utility, can you let me know which Api's you used to implement this utility
Thanks in advance
prasad_RR
(To:avillanueva)
I was just trying to automate classification node creation through API,But I failed with windchill API.
I wrote a utility which is generating xml file which can run using loadfromfile and it create nodes under given parents.
I wrote a utility that allows me to enter a DataType and a value.
The utility will search the database and return the <Table.Column> following by the value.
I did this on a node Display Name and a node Description.
Once I know which table the data is stored in, I can easily write a utility to do the update.
Do you have a list of node names and the desired values for Display Name and Description.
If you would like me to write the utility email me from your work email
windchill.developer@yahoo.com
David
prasad_RR
(To:d_graham)
To get Internal name and display name.Here is the query from database.
SELECT CN.idA2A2 AS PartId, name AS InternalName, CAST(LLPV.value AS VARCHAR(1000)) AS DisplayName, CN.idA3A4 as ParentID, CN.idA2A2 as Id
FROM db_windchill_dev.LWCStructEnumAttTemplate AS CN INNER JOIN db_windchill_dev.LWCLocalizablePropertyValue LLPV ON
LLPV.idA3C4=CN.idA2A2 AND LLPV.idA3B4=CN.idA2A2 AND LLPV.classnamekeyA4='com.ptc.core.lwc.server.LWCPropertyDefinition' and
LLPV.idA3A4 in (SELECT idA2A2 FROM db_windchill_dev.LWCPropertyDefinition where name='displayName' and
classname='com.ptc.core.lwc.server.LWCAbstractAttributeTemplate')
I tried multiple APIS like below but its not updating:
TypeDefinitionReadView nodeView = TypeDefinitionServiceHelper.service.getTypeDefView(AttributeTemplateFlavor.LWCSTRUCT, "com.ptc.csm.default_clf_namespace", name);
String str3 = nodeView.getName();
TypeDefinitionNodeView typeDefinitionNodeView = new TypeDefinitionNodeView(str3, lwcStructEnumAttTemplate.getPersistInfo().getObjectIdentifier());
typeDefinitionNodeView.setDisplayName("TestDisplay");
typeDefinitionNodeView.setDescription("TestDescription");*/
Yeah, I know how to get Internal name, display name, description, image, attributes, etc from a classification tree using sql and/or Windchill APIs.
I wrote a utility that can make updates to the nodes classification tree and well as classifying WTParts WITHOUT iterating the WTPart. To be honest, I have more experience with PartsLink than I want to have.
So, you have my email address if you want help send me an email.
David
VK_1647
(To:d_graham)
Hi ,
I need assistance to update classification attrubutes using api.
As i used persistable adapter but not updating attribute value.
Please need help as i have deadline for this.
I previously worked on the development of this feature, and there is API support for creating and updating node attributes. I don't check the community frequently.
