Add IBA to Promotion Target
dullnigAlex
Am I able to add an custom IBA to the Promotion Target?
Like the field promotion comment:
(in the red column should be a custom IBA)
Maybe I can customize it via code?
HelesicPetr
(To:Fadel)
Hi @Fadel
I just guess that he would like to add an IBA to a link between promotion and promotables that is a PromotionTarget type.
PromotionTarget type is not shown in the TypeAndAttribute management so I guess that it is not supported to add the IBA to the promotion target link.
general answer is No.
If you need some complex information during the promotion, use a change notice and make the workflow simple with any automation that helps users in their daily work.
PetrH
Fadel
23-Emerald I
(To:dullnigAlex)
on which type is the IBA defined ?
Fede
HelesicPetr
(To:Fadel)
Hi @Fadel
PetrH
